KZ400 shutting off
- Wicast3
KZ400 shutting off
16 Apr 2019 11:25 - 16 Apr 2019 11:26
I have an '81 KZ440 with ~16.5k miles.
Recently it has started to sometimes shut off on me when coming to a stop/idling, I generally can restart the bike by bump starting it. The starter does spin the motor when this happens, but it doesn't even try to start.
I've checked my battery and it is fine, it's charging how it should when the bike is running. The carbs have been cleaned and jetting is completely stock. The valves are in spec. The coils are ~2 year old Dyna 3 ohm coils, which were producing good spark when I checked.
This isn't a problem I can recreate, so I don't necessarily know how to test any fixes.
Any ideas?
Any ideas?
Last edit: 16 Apr 2019 11:26 by Wicast3.
- gordone
Re: KZ400 shutting off
16 Apr 2019 13:28
Can it be unstable/bad/poor connection some where?
Have you checked the fuses for poor connection?
Project:
Project:
- Wicast3
17 Apr 2019 11:00
My fuses are good and solid, I'll go around the bike and make sure all of the connectors are snug.
It's an odd situation, and it's frustrating me to no end.
