Valve chatter/left #1 carb Coughing
- nitromatt37
14 Apr 2019 09:00 - 14 Apr 2019 09:02
Ok guys I own a 1981 Kawasaki kz650H the bike sat for five years got it running changed all fluids did checked everything. When I first started the engine it had thd original oil from 5 years ago it wasn't sludged up but was thin, it started up made sure the carbs where synced right and it had an audible chatter sound from the left side of the top end the guy said the valves where adjusted on it right we checked it they seam right but I didn't check the spring or check if the valves where's hanging open but since i put the correct oil in 10w40 full synthetic the chatter went down but is still loud be in mind my bike is straight piped and i can still hear the chatter when sitting still but the noise stays the same no matter what rpm I'm at. U can hear the clatter in this video can someone explain it
Last edit: 14 Apr 2019 09:02 by nitromatt37.
- Warren3200gt
Re: Valve chatter/left #1 carb Coughing
14 Apr 2019 10:40 - 14 Apr 2019 10:43
No video attached so can't hear it but along with what you have already mentioned it could be shim bucket rocking in a worn head.
Had it on a 900 due to oil starvation due to blocked oil gallery thanks to not being cleaned properly after bead blasting.
Last edit: 14 Apr 2019 10:43 by Warren3200gt.
- nitromatt37
14 Apr 2019 11:52
Thanks man that could be it if ud like I could send u the video thru email and u could listen to it tell me wat u think I was standing a good 10 feet from the bike and u could hear it
14 Apr 2019 14:37
Try a free file hoster like zippyshare.com.
Upload your Video @ www.zippyshare.com and post the link to your video here.
