77 kz400d idle knob
  • alo77kz
  • alo77kz's Avatar Topic Author
77 kz400d idle knob
08 Apr 2019 12:13
#801808
Just picked up my first Kawasaki.. Been looking for awhile for a bike, truth is I'm a new rider and new to working on bikes. The one i found is my profile pic. .. 1977 kz400D with 14k miles on it.. Haven't decided if i want to fully restore or MOD it and make it a custom job.. Like the idea of trying to keep vintage with a bit of updates.. Bike starts on first kick and the electronic start works, think need to replace battery.. Question is, the owner I bought it from would manipulate a n idle knob when he started it cld.. Choked it to get started and rolled idle up a bit to get it warmed up then rolled back idle once it was warm.. is this common? Is this something that manipulating the throttle can do as well until the bike is warmed up?? Any pointers and help would be appreciated..
Thanks !
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 77 kz400d idle knob
08 Apr 2019 18:17
#801826
Yes, it is common to choke the carbs to increase the amount of fuel the engine receives during a start up when cold.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • TexasKZ
  • TexasKZ's Avatar
09 Apr 2019 04:42
#801844
Yes, using the choke is normal, but messing with the idle adjustment is not. The choke will cause the idle to be higher all by itself, assuming it is working properly. There should be no need to mess with the throttle.
