KZ1000 J3 carb cleaning
  • MartyZ1000
  • MartyZ1000's Avatar Topic Author
03 Apr 2019 09:28 - 03 Apr 2019 09:29
#801441
Yes I finally got around to cleaning the carbs a bit, all I did was take off the covers, blow the jets and check floats visually
and it all seemed ok, got rif of the NASTY screws as well and replaced with insix (whaddayacallthem?) ones instead.
Of course NOW the bike won´t start.
And I can+t figure out where I went wrong, for start with choke all that should matter is gas in and floats ok
not even that? Are the diaphragm mountings critical ina nay way they´re symmetrical right?
And vaccum opens the gas tap ok it´s just not getting inside the cylinders, sparks are dry...
PLEASE what is usually wrong help this stupid fuck brothers...
Last edit: 03 Apr 2019 09:29 by MartyZ1000.
  • MartyZ1000
Re: KZ1000 J3 carb cleaning
03 Apr 2019 22:46
#801481
Noone cleaned their carbs?
I took them apart and put togeteher numerous times, the diaphragms are in place right -
the only thing I´m not sure of is how the float covers should sit?
  • scubaanders
  • scubaanders's Avatar
04 Apr 2019 08:33
#801505
The drain screws shall face outwards, other wise there is not many ways you can put them.
If you don't figure it out, PM me your phone number and I will give you a call.
/Anders
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
  • scubaanders
04 Apr 2019 12:28
#801523
I saw on Facebook that u got it sorted Marty, good on u .
/A
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
