Bypass the breather - is this ok?
  • sharkmonkey
  • sharkmonkey's Avatar Topic Author
28 Mar 2019 16:55 - 28 Mar 2019 16:57
#801191
The previous owner of this bike cut out the breather box. There was an open hose that I used an elbow to bypass. Will the bike run ok like this? I haven't had a chance to ride it yet.
1983 Kawasaki KZ750 KZ1 LTD (belt)
1980 Honda CM400T
Last edit: 28 Mar 2019 16:57 by sharkmonkey.
The following user(s) said Thank You: ned37
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: Bypass the breather - is this ok?
28 Mar 2019 16:59
#801192
You say you've used an elbow to 'bypass' - where is it bypassing to?
The stock breather would breath into the airbox, so any crankcase fumes would be recirculated back into the engine for emissions reasons. Without an airbox there's nowhere to run the breather to, it needs to vent to the atmosphere. The standard way of doing this is to use a breather filter to prevent dirt from getting in, but still letting the crankcase pressure out. You can pick them up for a few dollars.
1981 KZ750 LTD
The following user(s) said Thank You: sharkmonkey
  • sharkmonkey
28 Mar 2019 22:36
#801207
Ok so bypass is probably not the correct word. I will look for a filter. Thank you
1980 Honda CM400T
  • Warren3200gt
  • Warren3200gt's Avatar
28 Mar 2019 23:48
#801208
  • sharkmonkey
29 Mar 2019 08:32
#801220
Thanks. I see the breather filter on the bottom. What did you do with the lines on the top? Is there another filter there?
1980 Honda CM400T
  • TexasKZ
  • TexasKZ's Avatar
29 Mar 2019 08:41 - 29 Mar 2019 08:42
#801223
You don't even need the filter. Some folks just run a hose straight up under the fuel tank and along the frame rail toward the back of the bike. As long as it is running generally up hill, any oil mist will run back into the crankcase. Prior to 1967, all automotive engines vented to atmosphere in a similar fashion.
If you are asking about the fairly large hoses coming out of the cam cover, you can connect them together, or block them off, or install threaded plugs in the passageway into the exhaust ports.
Last edit: 29 Mar 2019 08:42 by TexasKZ.
  • Warren3200gt
29 Mar 2019 08:45 - 29 Mar 2019 08:47
#801225
Or you could swop the cam cover for a non emissions version.
Last edit: 29 Mar 2019 08:47 by Warren3200gt.
  • sharkmonkey
29 Mar 2019 08:52
#801227
Ok, so I think that answers my original question "will it run".
The only reason I am asking is because I took the bike a ride around my neighborhood and when I would accelerate the carbs would pop. I thought maybe they were too lean because of the open hose.
1980 Honda CM400T
  • TexasKZ
  • TexasKZ's Avatar
29 Mar 2019 08:57
#801228
That popping may be the result of a very lean condition crated by removing the stock air filter box, and not properly rejetting the carbs. Does it also have open or very low restriction exhaust?
  • sharkmonkey
29 Mar 2019 09:12
#801230
The exhaust is stock.
I have also noticed it will not cold start/run with full choke.
1980 Honda CM400T
  • TexasKZ
  • TexasKZ's Avatar
29 Mar 2019 09:19
#801231
Could be clogged jets or shot carb holders. Do you know how it ran when the stock air filter box was in place?
  • TexasKZ
  • TexasKZ's Avatar
29 Mar 2019 09:25
#801232
sharkmonkey wrote: Ok, so I think that answers my original question "will it run".
Probably. It is hard to tell from the pic, but is the hose from the crankcase breather attached to the clean air system on top of the engine? If so, that is not the problem, though it will pump oil mist into the exhaust. That may or may not be a problem depending on how heavy the mist is.
