kz750 ltd wont start
- CDgomez1985
21 Mar 2019 11:41
hello new to forum...i recently purchased a 81 ltd750 and i cant get it started ......i have cleaned all connections checked grounds and have a brand new battery on it but the starter just turns super slow .....i dont know what else to do ....its been sittin for a while but changed the oil and cleaned card ....starter turn extra slow or it will just click.......any help would be appreciated
- jayrodoh
Re: kz750 ltd wont start
21 Mar 2019 12:04
Have you charged the new battery? What is the volt reading of the battery with ignition off? If battery is good and all connections are clean, you may need to pull starter and inspect brushes, gears, etc.
1982 KZ750-M1 CSR
21 Mar 2019 12:07
Would have the new battery "load tested" for free at Walmart, AutoZone or other dealer that sells batteries..
The following user(s) said Thank You: CDgomez1985
- CDgomez1985
21 Mar 2019 12:48
Battery's good .....just bought it but I'm going to take it in anyway
- baldy110
- CDgomez1985
- jayrodoh
22 Mar 2019 03:41CDgomez1985 wrote: Battery's good .....just bought it but I'm going to take it in anyway
New batteries can be bad. Have you charged it?
1982 KZ750-M1 CSR
- CDgomez1985
22 Mar 2019 13:56
yes battery fully charged instead of slowly turning engine it just clicks
- gordone
22 Mar 2019 15:59CDgomez1985 wrote: yes battery fully charged instead of slowly turning engine it just clicks
Just clicking? Start relay issue?
Project:
Project:
