Engine ID
- Phillystyle_13
Engine ID
16 Mar 2019 15:18
Just picked up my first kz and trying to learn a little about it. It’s an 81 Kz1000 Ltd. first question before I start ordering parts is the engine code. It reads kzt00JE033378
Now looking at Zedder.com I’m getting this iis out of an 82 model? If so is there anything different I should be looking for when I start to order up parts?
Re: Engine ID
16 Mar 2019 19:43
Mostly the same, though the clutch release mechanism was changed in 1982.
The following user(s) said Thank You: Phillystyle_13
Re: Engine ID
16 Mar 2019 19:44
You should order parts based on your frame serial number. You can find it on a white sticker on the neck. It's also stamped into the neck.
Re: Engine ID
16 Mar 2019 19:47
Unless it was a leftover 1981 frame and a really early 1982 engine, or if the engine is not original to the bike.
The following user(s) said Thank You: hardrockminer
