Ring break in period
- kzsolo
15 Mar 2019 14:18
'78 KZ750 Twin. Put new rings in it and after firing it up a few times (but no road miles yet) the plugs are a little oily. Cleaning reveals a nice tan insulator under the oil. I am assuming I need to get some miles in before the rings get properly seated. Will this go away quickly or do I need to have some spare plugs with me? Thanks
Re: Ring break in period
15 Mar 2019 14:55 - 15 Mar 2019 15:00
Spark plugs, (new rings for the break in), need a specific head for the self cleaning process = riding conditions.
Many cold starts, (fat air/fuel mixture) can fool your spark plugs and Piston rings very quick.
A fat air/fuel mixture can wash away the lubrication oil layer on the cylinder wall, scoring marks.
Last edit: 15 Mar 2019 15:00 by Scirocco.
- daveo
17 Mar 2019 18:00
When installing a freshly honed cylinder block, how much oil should there be on the cylinder walls?
1982 KZ1100-A2/1170 sleeper 😀
- DFIGPZ
- gordone
19 Mar 2019 15:10DFIGPZ wrote: I install all of mine ' DRY '
I recived same advise, with my build.
Project:
Project:
19 Mar 2019 16:57
I use just enough oil to avoid rusting (very light coat).
- gordone
22 Mar 2019 15:28
Have I understood it correct, if you use to much the ring will not brake in?
After reborring and honing, I needed to remove cuttings with oil and a rag, so the wall was coated as Nessism advise.
Project:
Project:
