Stator wire grommet
- ZeffRides
Stator wire grommet
09 Mar 2019 16:58
Is there a source for the stator wire grommets for the KZ750 twins? (1976)
1976 KZ750B1
1978 CB750K
2002 BMW 530i 5-speed
1978 CB750K
Re: Stator wire grommet
09 Mar 2019 19:25 - 09 Mar 2019 19:26
The parts diagram appears to show two grommets as integral pieces of the stator wires, not listed as separately available. My wild guess is that the design doesn't contemplate replacement of just the grommets themselves.
If leaking oil is the issue, the following described type of procedure might help stop the leaking.
Kidkawie wrote: It's pretty common for it to leak there. I believe the cloth on the wires wicks the oil out or there isn't a good bond with the grommet and wires. I sealed mine 5-6 years ago and hasn't leaked yet. I removed the cover and cleaned the snot out of the wires/grommet area using brake clean. I'd let it completely dry, then clean again. I did this about 6 times until there was no traces of oil on the wiring or grommet area. I used liquid gasket and let it seep into the cloth of the wires and pool on top of the grommet. Also filled in the cavity just below the grommet with silicone and sealed the grommet to the aluminum. Let it dry in the bench for a coupla days before reinstalling.
Last edit: 09 Mar 2019 19:26 by Patton.
