Kz750 slipping into neutral.
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
27 Feb 2019 03:11 - 27 Feb 2019 05:37
#799297
It went like this, kinda like a pop or a misfire two or three times then it pops into neutral.
All was well with the bike. I replaced my starter which requires you to remove the shifter and did a carb sync which allowed for a lower rpm and did some final drive work. It still has a small leak I think.
Any ideas as to why it’s popping into neutral?
Last edit: 27 Feb 2019 05:37 by JohnLuke.
  • TexasKZ
  • TexasKZ's Avatar
Re: Kz750 slipping into neutral.
27 Feb 2019 06:21
#799313
Often that is a sign that the engagement dogs on that gear are rounded off. Could be a bent shift fork. Has the bike been subjected to a lot of ham-fisted (footed?) shifting or a lot of drag racing?
  • JohnLuke
27 Feb 2019 11:54
#799341
No not really. I just took it on a ride and reall made sure the gear was fully engaged. Seemed to work fine.
