Oil coolers
- Troy marcum
Oil coolers
15 Feb 2019 19:45
I'm looking for an oil cooler for an 81 kz 650 csr. Any suggestions out there?
Re: Oil coolers
15 Feb 2019 20:23
Just curious - do you live in an unusually hot climate or is it a dedicated race bike? Otherwise an oil cooler wouldn't normally be needed on a KZ650. Ed
Re: Oil coolers
15 Feb 2019 22:24
I added an oil cooler to my 750 engine by using an oil pan with the oil cooler feed ports from a GPz and then (of course) a GPz cooler. Works perfectly.
This thread on the topic may help you... www.kzrider.com/forum/2-engine/609758-oil-cooler-kz-550?start=0
- Blue58
- Old, Bald and Fast
Re: Oil coolers
16 Feb 2019 05:33 - 16 Feb 2019 05:35
I did add a cooler to my 650. You need a gpz750 oil pan and cooler with lines. Not to hard to do and you can do it with the engine in the bike . Easer if you have a lift table or some way to get the bike off the ground so your not crawling on the floor to work on it. But it's a straight swap.
Last edit: 16 Feb 2019 05:35 by Blue58.
The following user(s) said Thank You: Olajoe
