Will a B model exhaust fit an H model?
- Troy marcum
07 Feb 2019 06:49
Is there any difference in the frame that will cause clearance issues? It isn't easy to find an affordable exhaust that specifically states it will fit. Thanks!
Re: Will a B model exhaust fit an H model?
07 Feb 2019 08:36 - 07 Feb 2019 10:23
Need to know the specific models. the letters alone are pretty much meaningless as there were several different sized KZs of each.
Last edit: 07 Feb 2019 10:23 by martin_csr.
- Troy marcum
07 Feb 2019 10:19
I need or want to put a Vance and hines 4 into 1 exhaust on a 81 kz650&;csr. But all I find are exhaust for 77 thru 80 kz650 b models. I know it'll bolt up to the engine and all, just concerned about any difference in the frame. I think it'll be ok but if anyone knows for sure. Let me know. Thanks. Don't wanna spend that kinda money unless it fits properly.
07 Feb 2019 10:43 - 09 Feb 2019 08:15
Probably any KZ650 KZ750 4-1 exhaust system fits just about any 650 or 750-4. You may have to fabricate a muffler bracket. If you can't find anything listed for the KZ650-CSR, try searching for KZ750 Ltd instead >> the 750H has the same frame & muffler system.
Also, I think Z1Enterprises sells Delkevic ss exhaust systems.
Kind of related, here's a 70s 650 with a stock ZR750 ss muffler system.
ZR7 or ZR7S w stock exhaust. same as pic above.
1981 KZ650-CSR w 1980 KZ750-E1 mufflers. direct fit. the 750E mufflers are 6" longer than the csr.
just showing that some 650 750 systems can be interchangeable. the E frame is similar to the csr.
Last edit: 09 Feb 2019 08:15 by martin_csr.
