Valve cover
  • gordone
  • gordone's Avatar Topic Author
Valve cover
04 Feb 2019 07:35
#798169
I need some advise to be able to reuse the valve cover for longer times.
1. I have tried not do anything, then I damaged it the first time I took off the cover.
2. I have tried to apply grease, but then it sweat when I use the bike....
What can I do?
Project:
  • martin_csr
  • martin_csr's Avatar
Re: Valve cover
04 Feb 2019 08:34 - 04 Feb 2019 08:46
#798177
Do you mean the gasket?
One method for preserving the gasket. Remove all of the valve cover bolts. except for the bolts on the ends >> loosen those so that there is a few mm of clearance above the valve cover. Then using a suitable pry tool & mallet, break loose the valve cover >> tap or whack the pry tool with the mallet. Then lift the valve cover a little & use a flat tool or blade to separate the gasket from one of the surfaces >> whichever surface the gasket has already come loose from the most. Then remove the end bolts & carefully remove the valve cover, making sure the gasket isn't stuck anywhere & pry/separate the gasket from the surface as necessary.
Also, to reuse a paper gasket, I spray the gasket with Liquid wrench silicone spray lubricant. spray the gasket to saturate it, then let the gasket sit overnight in a plastic bag. note: some silicone spray has acetone, CRC brand for example. I don't like the idea of acetone in silicone spray.
Last edit: 04 Feb 2019 08:46 by martin_csr.
  • gordone
Re: Valve cover
04 Feb 2019 09:19
#798182
Thank you, good plan!
Project:
  • martin_csr
Re: Valve cover
04 Feb 2019 09:51 - 05 Feb 2019 05:42
#798185
Paper gaskets I've sprayed with LW silicone: float bowl gaskets. pulsing coil cover gasket. generator cover gasket. valve cover gasket.
As you already know, you have to be careful about what you put on gaskets. Something like a valve cover won't matter that much, because it's relatively easy to replace that gasket. The generator & pulsing coil cover gaskets are normally dry (ie, no contact with engine oil), so spraying them or using grease shouldn't matter with those gaskets either.
ps: a can I had from several years ago specifically listed treating paper gaskets as one of its uses.
Last edit: 05 Feb 2019 05:42 by martin_csr.
  • gordone
Re: Valve cover
04 Feb 2019 12:06
#798193
I will use silicon spray next time I do valve shimming.
Project:
