compression test psi
  • askrider
  • askrider's Avatar Topic Author
30 Jan 2019 09:46
#797915
Hello all just wanted to know does any one know what the psi is for a compression test on the cylinders on a 1980 kz 750 e1.
Kind Regards
Andy
  • martin_csr
  • martin_csr's Avatar
Re: compression test psi
30 Jan 2019 11:42 - 30 Jan 2019 11:48
#797925
The values should be in the 750-4 manual. There's a pdf available >> Gold cover w color wiring diagrams.
I did not see the data for the 1980 model year, but the 1983 supplement says the Standard compression is 162 - 191 psi with less than 14 psi difference between any 2 cylinders. The Service Limit is listed as 124 - 191 psi, again w less than 14 psi difference between any 2 cylinders. I'd guess the 80-82 750-4 specs are the same.
Last edit: 30 Jan 2019 11:48 by martin_csr.
The following user(s) said Thank You: askrider19
  • askrider
30 Jan 2019 12:03
#797927
Thank you so much
Regards
andy
  • Nessism
  • Nessism's Avatar
30 Jan 2019 15:10
#797935
If the engine has sat for some time the compression may be abnormally low due to sticky rings, and with some miles that situation may well improve. And it's critical to adjust the valves before performing a compression test because the valves tighten with mileage and a lot of people don't know what maintenance is.
Good luck
