wet plugs
  • djbragg
  • djbragg's Avatar Topic Author
wet plugs
27 Jan 2019 05:40
#797676
pulled plugs on 1976 kz900 and they looked wet? any ideas?
put in new float gasket bowls and only two bowls had gas in them???
  • hardrockminer
  • hardrockminer's Avatar
Re: wet plugs
27 Jan 2019 06:04
#797677
My overriding thought is that you have a fuel issue. I would start at the fill neck on the tank..check the gas cap to make sure it's venting OK. Check the tank for rust, dirt or water. Check your fuel lines to ensure fuel is running without blockage.
Pull your carbs, dismantle and check the Tees on the inlet side. Any blockage?
Check you floats for proper height. Check your float valves...do they open and close easily? Does fuel flow through them?
Unscrew the choke valves and clean them.
  • djbragg
Re: wet plugs
27 Jan 2019 10:12
#797702
already did all of the things you said, thanks though
