KZ650 Clutch Issue
Re: KZ650 Clutch Issue
01 Feb 2019 04:38
Did you use an impact driver w/#3 bit to try to remove the screws?
The following user(s) said Thank You: jjdkl
01 Feb 2019 05:21 - 01 Feb 2019 06:23
Unrelated to the clutch adjustment. Someone got rid of the oil gauge sight glass. I would look into installing a new one. I believe Z1Enterprises has them. Or if need be, replace the clutch cover with one having the sight glass.
Last edit: 01 Feb 2019 06:23 by martin_csr.
01 Feb 2019 06:58
Looks like someone rattlecaned over the sight glass. It should be possible to clean the lens.
- jjdkl
01 Feb 2019 07:08
Yes it's painted over. I'll clean it or get a new one once the cover is off.
- jjdkl
03 Feb 2019 21:48
Many thanks to Nessism. The impact driver worked like a charm. The cover is off. I removed the lifter plate pusher and the ball bearing was in there. I then noticed that the clutch hub nut was loose. Like finger tight loose and it had backed off. I could turn it with my fingers. When the PO replaced the clutch he apperantly didn't torque it to spec and it worked itself loose. I assume that when I was pulling in the clutch lever the whole clutch assembly had moved out and that's why I ran out of adjustment. All the plates appear fine. I just need to tighten the nut down. Is this possible without the special tool? I've seen online some references to using a strap wrench. Has anyone done this? Thanks again for all the help everyone.
- KZB2 650
04 Feb 2019 06:41 - 04 Feb 2019 06:51
You can get a EBC holder tool off Ebay for 18 bucks or so.... a strap might work but you really gotta crank on it... 100 lbs or just under...... you really should replace the nut too since it had a locking tab built into it (the manual recommends it along with the thrust washer which I did too (maybe could by without it though??) ... I used blue loctite too just to be safe. Good job on finding the problem before it got dangerous for ya.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 04 Feb 2019 06:51 by KZB2 650.
- jjdkl
04 Feb 2019 06:59
Just bought the ebc holder and nut on EBay. Thanks KZB2!
- Daftrusty
04 Feb 2019 19:45
Good catch on finding the cause of your issue! That would have made a mess if that nut came off when you were riding.
1990 zr550
kz750e
650/750 6-speed Transmission Swap
kz750e
- jjdkl
27 Feb 2019 07:01
Final Update: After much delay due to work, family, wrong parts, and a much needed short vacation everything is back together, torqued properly, and working great. Thanks to everyone for their help and knowledge getting this fixed. Very much appreciated.
- BlackEyeCafe
12 Aug 2020 14:19
Are you able to provide the source for you lock nut? I can't seem to find one anywhere.
Thank you
Thank you
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
