Kz750 spectre
  • Dareniles
  • Dareniles's Avatar Topic Author
Kz750 spectre
16 Jan 2019 15:22
#796900
Hi, I am trying to replace the stator on my spectre - I removed the four bolts from the casing but can’t budge it - am I missing something? Thanks
  • mopguy
  • mopguy's Avatar
Re: Kz750 spectre
16 Jan 2019 16:09
#796904
You need to remove three bolts on stator.
  • Nessism
  • Nessism's Avatar
Re: Kz750 spectre
16 Jan 2019 16:40
#796908
If the cover is stuck try whacking it with a rubber mallet. Not too hard of course. There is a hollow metal dowel which keeps the cover aligned. That and the gasket tend to hold the cover firm after some years.
  • martin_csr
  • martin_csr's Avatar
Re: Kz750 spectre
17 Jan 2019 05:42
#796925
Plus I recall that there's the magnetic force. but it's most likely just stuck from probably never being removed before.
