kz750 oil pump
  • gixxerkidd03
  • gixxerkidd03's Avatar Topic Author
kz750 oil pump
06 Jan 2019 15:19
#796289
i pulled my oil pan to change the pan gasket today and noticed the oil pump screen looks to of have had a lot of suction behind it and the rubbber gasket was mis shaped and crushed a little.
anyone ever seen this ?
1981 KZ750e
  • Irish Yobbo
  • Irish Yobbo's Avatar
Re: kz750 oil pump
06 Jan 2019 15:45
#796293
I have, but only because it was blocked with silicone and debris (picture in this thread: www.kzrider.com/kunena/2-engine/599503-a...-the-silicone#688011 ).
Make sure it's clean, if it's clean then there shouldn't be much resistance, in the same way that blowing on a flyscreen door doesn't move it much. It could have been blocked previously and then cleaned, which may explain the distortion?
1981 KZ750 LTD
