81 kz750 engine I think ?
- 750killacycle
31 Dec 2018 05:24
Hello, I'm new here trying to find some info on an ATV I picked up engine I believe is a 81 kz750 looks to have the mikuni 29mm smoothbores on it just looking for some help identifying some of these pieces to see what I got here it has nitrous on it as well so thinking motor was built for it, hopefully
Re: 81 kz750 engine I think ?
31 Dec 2018 06:51
CycleChaos.com has the engine & frame number info for many Kawasaki models.
- 750killacycle
31 Dec 2018 08:36
I'm pretty sure it's an 81 kz750 per engine number I'm trying to figure out about mixing parts how to identify which head it has if the carbs are infact 29mm smooth bores etc
- les holt
31 Dec 2018 08:43
Those are %100 29 smooth bores.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
The following user(s) said Thank You: 750killacycle
- 750killacycle
31 Dec 2018 09:24
That's awesome from what I've been reading there a really good carb for this bike I'm gonna be tearing down the top end here soon anything I should look for or is there any heads better then the other I read that the gpz head was better how do I tell what's on there?
- gordone
31 Dec 2018 18:02
For personal intrest, what is the tubing on the inlet, measure vaacum?
Make a project thread?
Project:
Project:
31 Dec 2018 19:40 - 31 Dec 2018 19:411981 KZ750 Engine No. Range per Zedder:750killacycle wrote: I'm pretty sure it's an 81 kz750 per engine number....
KZ750EE024601 - 062600
Last edit: 31 Dec 2018 19:41 by Patton.
- 750killacycle
01 Jan 2019 11:37 - 01 Jan 2019 11:37
The tubing is the plumbing for the nitrous, also can anyone identify these pistons? And I'm still new to foru.s in general should I just start a topic about my project?
Last edit: 01 Jan 2019 11:37 by 750killacycle. Reason: Add image
- les holt
01 Jan 2019 12:33
Look up inside them from the bottom, there is usually a tell tale mark or symbol that'll give you the answer, I would say they are higher compression than stock. Take a look at the ends of the cams and see if they're aftermarkets, again, usually some kind of marks.
Les Holt
Les Holt
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
76 kz 900 turbo
77 LTD 1000 turbo
2 78 Z1R's
72 H2
- 750killacycle
01 Jan 2019 13:48
There's an mtc cast in bottom I'll look closer when I get home, thank you for info
- KZB2 650
02 Jan 2019 06:33 - 02 Jan 2019 06:39
I can see why its called the kilacycle........ 750 motor on a 4 wheeler with high comp MTC pistons and nitrous is crazy ..... but in a good way.
I can still remember buying the Hot bike magazine with the article on the nitrous kit they put on a 900 Kaw in the early 80s..... dreamed and planned on doing it but was mainly scared of damaging the motor (and myself) and also was always low on funds too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 02 Jan 2019 06:39 by KZB2 650.
- 750killacycle
02 Jan 2019 06:52
Haha yeah I like this thing I picked it up dirt cheap it was an animal but was smoking I'm trying to freshen up top end finding it difficult to track down rings these pistons are +2mm I emailed mtc I'm hoping they can help find rings for them
