Old style oil scraper ring installation
- shamal
27 Dec 2018 00:59
Good morning i need advice. I have to install some of that old style oil scraper piston rings that are only one piece, with a little spring inside. They seem to be very easy to crack..
There is a trick? I broken some of the old ones during removal and now im concerned about installation. Especially, should i insert the spring in the piston slot Before, OR not? Please help
1983 kz 550 h
Re: Old style oil scraper ring installation
27 Dec 2018 02:07
Some pics of the of that old style oil scraper piston rings would be helpful
The following user(s) said Thank You: shamal
- shamal
27 Dec 2018 02:59
Im talking about the ring in this pic
pt-pcs.federalmogul.com/ProductImages/4b...9e5b5eb7c2e4_thm.jpg
Its a one piece ring, not like the newest 3 piece oil rings
1983 kz 550 h
- shamal
27 Dec 2018 15:12
Found on Youtube
- shamal
28 Dec 2018 04:23
Thanks, ihave not that tool. I wonder if someone had this problem here before and if can tell me the way to install that single piece scraper ring without break it..
1983 kz 550 h
28 Dec 2018 05:30
What kind of vehicle are we talking about here? Those one piece rings are inferior to the three piece type when it comes to oil control.
- shamal
28 Dec 2018 06:12
Is a old little 350 guzzi. Im concerned because i broke some of the old during dismantling..
1983 kz 550 h
