Kz750 exhaust
- missionkz
Re: Kz750 exhaust
27 Dec 2018 13:19 - 27 Dec 2018 13:20
I hate painted header pipes and how God awful they look after a couple days
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 27 Dec 2018 13:20 by missionkz.
- missionkz
Re: Kz750 exhaust
27 Dec 2018 13:21
That INOX-SPECTRAL is pretty cool but a 2" pipe diameter max, according their website.... most collectors are much wider in diameter.
Bruce
1977 KZ1000A1
1977 KZ1000A1
- gordone
Re: Kz750 exhaust
27 Dec 2018 15:16
Should I replace my studs and nuts with A4/316 when I install the new Delevic system?
Project:
Project:
Re: Kz750 exhaust
27 Dec 2018 15:30
Resistance to Corrosion
304 stainless steel also known as A2 stainless steel is resistant to corrosion however 316 stainless steel also known as A4 stainless steel provides a higher degree of corrosion resistance because it contains molybdenum in its composition. Therefore making 316 A4 stainless steel a better suited steel for resistance to extreme environmental conditions like exposure to chemical solutions, brine solutions, de-icing salts and of course salt water. 304 stainless steel or A2 as some like to call it will tarnish after a while but will resist corrosion for a time
www.jclarkemarine.com/blogs/news/5322938...-304-vs-316-a2-vs-a4
- gordone
Re: Kz750 exhaust
27 Dec 2018 15:51
Thank you, I was expressed myself poorley...
What I was thinking about was mixing different type of steel.
I will by new studs and nuts.
Project:
Project:
- rstnick
Re: Kz750 exhaust
27 Dec 2018 15:54 - 27 Dec 2018 15:58gordone wrote: Should I replace my studs and nuts with A4/316 when I install the new Delevic system?
I didn't.
Used the stock studs, but bought some new nuts at a hardware store. Probably made of zink.
I don't think the Delkevic is too loud.
I'm using the supplied baffle.
Other's have said it sounds really good.
A video for sound:
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 27 Dec 2018 15:58 by rstnick.
- gordone
Re: Kz750 exhaust
28 Dec 2018 10:25
Thank you, nice sound!
Have you done something with the jetting?
I hope don’t need todo something since I have 4-1 system now also.
Project:
Project:
- rstnick
Re: Kz750 exhaust
28 Dec 2018 13:00
I had a Kerker 4 into 1 before the Delkevic.
And no did not do any jetting changes, but have not had stock jetting in years.
My 650 had a 4 into 1 when I bought it.
Have never had a stock exhaust on her since I've owned it.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- gordone
Re: Kz750 exhaust
28 Dec 2018 13:57
Okey, I also have 4 to 1 now, but it’s kind of homemade, cross my fingers I don’t need todo anything with the carbs, got them working great in the summer after much trouvleshooting.
Project:
Project:
- gordone
Re: Kz750 exhaust
27 Feb 2019 02:28
The bike is running good with existing 4 to 1 exhaust system, and I will upgrade to Delkevic now, is there big possibility I need to do something with the jets?
Carbs VM24 (original from 650 engine) have upgraded to 750 engine with 810 bigbore.
Pilot: 17.5
Main:112.5
Needle: 4`th position one from top.
Thank you all.
Pilot: 17.5
Main:112.5
Thank you all.
Project:
Project:
- baldy110
Re: Kz750 exhaust
27 Feb 2019 06:32 - 27 Feb 2019 06:34
If you got the carbs dialed in prior to the big bore kit I would leave the jetting alone. I'll bet your pretty close even with the bigger pistons.
Last edit: 27 Feb 2019 06:34 by baldy110.
- gordone
Re: Kz750 exhaust
27 Feb 2019 07:05 - 27 Feb 2019 07:06baldy110 wrote: If you got the carbs dialed in prior to the big bore kit I would leave the jetting alone. I'll bet your pretty close even with the bigger pistons.
I have got the jet good (engine is working fine) with bigbore only new variable is the new 4 to 1 exhaust system.
Project:
Project:
Last edit: 27 Feb 2019 07:06 by gordone.
