New tach drive seal kit
  • Ronnie_D
  • Ronnie_D's Avatar Topic Author
  • 1978 KZ1000 A2
12 Dec 2018 11:03 - 12 Dec 2018 11:04
#795023
Hello:
I am going to put in a new tach drive seal, o-ring and gasket to fix the leak on my 1978 KZ1000. I am wondering if the drive unit comes out easily or is there a trick to getting it out of the head? I will also be putting in a new cam cover gasket at the same time.
Your help and advice is appreciated.
cheers,
Ron.
Last edit: 12 Dec 2018 11:04 by Ronnie_D.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: New tach drive seal kit
12 Dec 2018 11:13
#795025
Push it out with light taps on an wooden stick
The following user(s) said Thank You: Ronnie_D
  • hardrockminer
  • hardrockminer's Avatar
12 Dec 2018 12:05
#795027
It should come out easily but you may need to turn it several turns because the gear mates with a gear on the exhaust cam.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
12 Dec 2018 12:47 - 13 Dec 2018 07:05
#795035
The hardest part is likely to be getting the screw loose that holds the drive to the head. Recommend using an impact driver with a JIS bit that fits the screw head correctly.
Once the screw is out the drive will pull straight out of the head.
You might need to grasp it with pliers to move it initially. Careful to grasp it only on the smooth inner edges closest to the head to not damage the threads that the tach cable sleeve screws onto.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 13 Dec 2018 07:05 by slmjim+Z1BEBE. Reason: Clarification
  • Ronnie_D
  • 1978 KZ1000 A2
12 Dec 2018 13:38 - 12 Dec 2018 13:42
#795036
thank you for your advice. I will use all these approaches to remove the drive asm.
I like my JIS drivers I bought.
cheers,
Ron.
Last edit: 12 Dec 2018 13:42 by Ronnie_D.
  • hardrockminer
12 Dec 2018 14:23
#795040
Ronnie_D wrote: thank you for your advice. I will use all these approaches to remove the drive asm.
cheers,
Ron.
Best investment one can make for working on Japanese bikes!
