33 psi on all 4. 82 kz1100
  • lowkeyfilmz
  • lowkeyfilmz's Avatar Topic Author
10 Dec 2018 15:28
#794908
Been working on this bike for a couple months.
Got it cheap, motor didnt match neck numbers.
Bike sat outside semi covered for a couple years.
Got it to fire once and it reved pretty high.
(Vacuum and slides im guessing)
Kill switch didnt work so I yanked the wire which in turn probly fried the ic ignitor.
Took it to a buddies shop w a new to me used dyna 2000 w coils and timing magnet and pickups.
He got it wired and fired (i think) and says we got low compression on all 4. (31-38psi)
Im headed over there tommarrow w bore scope.
Read allot on here and lools like it could be timing chain skipped, valves or stuck rings.
Hopping to put a couple drops of blaster and or marvel in holes to free up rings.
He is pulling cam cover now.
Any afvice for folks who have been down this road?
  • hardrockminer
  • hardrockminer's Avatar
Re: 33 psi on all 4. 82 kz1100
10 Dec 2018 17:24
#794913
If the timing chain has slipped you should check your valves as you may have bent some. It happened to me last summer on a rebuild I was working on.
  • M_a_t_t
  • M_a_t_t's Avatar
10 Dec 2018 18:05
#794914
Does the compression tester you used have a valve in the end of the hose? If not it will skew the results a little. It's not going to bring you up from 30 to 120 or anything, but like 10-15 psi off I would guess.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • Big Jay
  • Big Jay's Avatar
  • Banned
  • Banned
10 Dec 2018 18:41
#794916
Was the throttle wide open during the test?
  • Nessism
  • Nessism's Avatar
10 Dec 2018 19:12 - 10 Dec 2018 19:12
#794917
The engine won't run at 33psi.
Last edit: 10 Dec 2018 19:12 by Nessism.
  • Irish Yobbo
  • Irish Yobbo's Avatar
11 Dec 2018 13:05
#794959
I agree with Nessism, something is wrong with the measuring if they're all at 33psi but you managed to start it.
100psi would be considered very low and you'll have trouble running. 33psi is near nothing. Check that your compression tester reads correctly (maybe try a different, working vehicle).
When you have the cam cover off, set the engine to top dead centre and check that the cam sprockets match up with what's in the manual, and while you're there check that the tensioner is working correctly, and that the valves all have clearance.
1981 KZ750 LTD
