GPZ750 engine mounts
  • Chamber66
  • Chamber66's Avatar Topic Author
05 Dec 2018 08:33 - 05 Dec 2018 08:55
#794673
Are the engine mounts on the GPZ750 identical to those on the KZ750? I need a top crank case for my KZ I can only find GPZ and zx750 ones in the UK
Last edit: 05 Dec 2018 08:55 by Chamber66.
  • Nessism
  • Nessism's Avatar
Re: GPZ750 engine mounts
05 Dec 2018 09:45
#794676
The engine was rubber mounted on the GPz and later bikes, and both the crankcase and frame mounts are different. I briefly contemplated rubber mounting my 750 engine but after realizing how much work would be involved, I gave up.
BTW, crankcase halves should always be kept together as an assembly because they are line bored together. There is some president for swapping halves, but it's not an ideal situation.
  • azman857
  • azman857's Avatar
05 Dec 2018 20:26 - 05 Dec 2018 20:35
#794709
I put a 750GPZ R1 engine in my '77 KZ650B frame. Just without the rubber mountings. The case was not changed, just the frame was changed for the rubber mounting. Yes. cases are machined together and need to stay mated for bearings can work and cases wont leak.
Last edit: 05 Dec 2018 20:35 by azman857.
  • Chamber66
05 Dec 2018 23:59
#794716
Actually my motor seems to be a KZ750 L4. problem is it's in a Harris magnum frame made specifically for these mounts
  • davido
  • davido's Avatar
06 Dec 2018 00:16
#794717
Photos?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • zukdave
  • zukdave's Avatar
06 Dec 2018 18:38
#794749
GPZ750R1 is a KZ motor a GPz750 is a ZX750 motor there not the same thing,
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • Nessism
  • Nessism's Avatar
09 Dec 2018 05:00
#794847
For what it's worth...apparently I was wrong with my comment earlier in regard to the crankcase halves being different to accommodate rubber mounts. Martin pointed this out in a different thread; the KZ750 and L3 model 750's (which used rubber mounts) share the same part number crankcases. The frame is different for sure, to allow for the different mounts, but you may very well be able to fit a later engine that was previously rubber mounted.
