compressed head gasket thickness
  • DoctoRot
  • DoctoRot's Avatar Topic Author
12 Nov 2018 14:05
#793729
I'm trying to determine the static compression on my kz750 twin. I have all the figures i need except the compressed head gasket thickness. Everything i have found says "consult manufacturer" for these numbers. My plan right now is to throw in a gasket, compress it and then measure the thickness of the copper rings that are embedded in it. Is this a good way to get this number?
  • hardrockminer
  • hardrockminer's Avatar
Re: compressed head gasket thickness
12 Nov 2018 14:41
#793730
I don't know if that will work but another way is to put the head on and torque it up without the gasket. Measure from some point below the head to a point on the head. Then pull the head and install the gasket. Torque it up and measure again.
  • Nebr_Rex
  • Nebr_Rex's Avatar
12 Nov 2018 16:13
#793739
I have a new KZ400 gasket and a used one also.
I measured them about a week ago. The new one is .062
and the used one is .050.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
