Replace Head Nuts
  • gordone
  • gordone's Avatar Topic Author
Replace Head Nuts
03 Nov 2018 11:07
#793324
I was thinking replace my heads nuts with some black one... but I have some questions around these.
1. If I replace one nut at the time, is there any risk the top gasket can be damage, its new from last year... and I don`t want to generate some exstra work?
2. Anybody know somebody selling black look head nuts for my 750 engine (92015-076) ?
Thank you.
Project:
  • hardrockminer
  • hardrockminer's Avatar
Re: Replace Head Nuts
03 Nov 2018 12:43
#793328
As long as the head isn't dislodged you should be fine. What I would do is remove all the existing head nuts and then replace them, tightening in the recommended sequence with a good torque wrench.
  • Nessism
  • Nessism's Avatar
03 Nov 2018 14:44
#793329
I'd do them one at a time. As for nuts, APE sells some nice ones but not sure if they are the same size as stock.
  • gordone
03 Nov 2018 15:16 - 03 Nov 2018 15:31
#793331
Nessism wrote: I'd do them one at a time. As for nuts, APE sells some nice ones but not sure if they are the same size as stock.
I also think the best is to take one by one when it comes to the gasket.
APE, these you was thinking about, APCHN1000K?
www.z1enterprises.com/cylinder-head-nuts-ape-hd-set-of-12.html
Think these is the same one ?
Project:
Last edit: 03 Nov 2018 15:31 by gordone.
  • Nessism
  • Nessism's Avatar
Last edit: 03 Nov 2018 16:59 by Nessism.
The following user(s) said Thank You: Barry1, gordone
  • gordone
30 Nov 2018 10:18 - 30 Nov 2018 14:01
#794406
No eBay APP ID and/or Cert ID defined in Kunena configurationSomebody know if these will fit, seller inform about size and threads below?
OEM Kawasaki is also 10mm so they should fit, maybe they are some taller, but it should not be a problem ?
Looks like OEM is 17.5mm high and APE is 22mm, but that should not be a problem ?
APE CHN1000K
You are looking at a brand new in box complete "cylinder head nut" kit as shown in the picture (made in the USA) size10mm x 1.25 with 7/8 base diameter. These super heat treated cylinder head nuts are a must for high output engines. Help prevent blown and leaking head gaskets caused by the threads in the soft stock nuts stretching. APE nuts are machined from alloy steel and fully heat treated for maximum strength. All APE nuts come with "APE" stamped on the head, be ware of imitations..
Project:
Last edit: 30 Nov 2018 14:01 by gordone.
  • Big Jay
  • Big Jay's Avatar
  • Banned
  • Banned
30 Nov 2018 21:31
#794416
They are a direct replacement.
  • gordone
01 Dec 2018 00:34
#794422
Thank you, APE said the same on email.
Nuts on the way in mail :)
Project:
  • Big Jay
  • Big Jay's Avatar
  • Banned
  • Banned
01 Dec 2018 17:34
#794456
You won't be disappointed.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
01 Dec 2018 18:49
#794458
gordone wrote: Thank you, APE said the same on email.
FYI to Gordone
Big Jay IS APE
He definitely would know his products
I use those black nuts on my turbo bike along with many , many other APE parts
  • gordone
01 Jan 2019 09:14
#796010
Thank you all, today have I replaced the head nuts:
kzrider.com/forum/11-projects/607213-650...gine?start=60#796009
Project:
  • gordone
03 Jun 2019 14:39
#805089
The APE bolts have started to rust?
I`m disappointed, they are rusting, shall they do that ?
Some moths ago:
Right now:
Project:
