What is the cover opposite of the stator cover? KZ750
- dpivas7
02 Nov 2018 12:50
What is the cover that is opposite of the stator cover on a typical kz750? The stator is on the left and it has the word Kawasaki on it, but on the right side, next to the clutch basket cover is the same looking cover, but I'm not sure what it is covering.
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
Re: What is the cover opposite of the stator cover? KZ750
02 Nov 2018 12:59 - 03 Nov 2018 06:49
Pulsing coil cap or cover. Under that cover is the pulsing coil & timing advancer for the ignition system, and the oil pressure switch is under there as well.
For reference see the diagrams at Kawasaki.com or Partzilla. cmsnl.com is another place, but partzilla is probably the easiest to use.
Last edit: 03 Nov 2018 06:49 by martin_csr.
- gordone
02 Nov 2018 15:28
Take it off and take a look
Project:
Project:
- gordone
02 Nov 2018 15:28
Project:
Project:
03 Nov 2018 06:47 - 03 Nov 2018 07:06
It's kinda handy to know beforehand. Get a gasket or two before removing it as an old gasket is probably going to get ruined.
Since the pulsing coil cover has to be removed to service the timing advancer & check the valve clearance, you might want keep several
gaskets in stock. sometimes you can get a lot of 2 or 3 or more for pretty cheap on EB.
There's a good 750-4 pdf available. yellow-gold cover & color wiring diagrams. 750turbo.com --- Index.
1980-84 750-4 & KZ700. 1983-85 ZX750. pdf manual link fifth from the bottom of the list - ->> GPz750 Base Manual.pdf.
Last edit: 03 Nov 2018 07:06 by martin_csr.
