Gasket kit for 1978 KZ 1000 engine
- Sayonara
- The faster the better
08 Oct 2018 16:12
Hello I will be needing a top end gasket kit for and engine i will be doing and I wonder which is the best kit you guys can recommend, especially as sometimes not OEM Valve seals can be an issue if are not the good quality ones. or should I buy the gasket set and separate high quality valve seals, and if so which ones, Sorry but I have been out the game since the age that OEM part were easy to purchase.
Thanks for your time it means a lot
I grew up riding and fixing all sort of small bike until I inherited A 1977 GS 750 when I was 16, that changed my life completely I love metric bike and I own a few fully working and have some projects.
Re: Gasket kit for 1978 KZ 1000 engine
08 Oct 2018 18:38
There is a member here that sells viton valve stem seals. Other than those the OEM gaskets and seals are superior to aftermarket in my experience.
- Sayonara
09 Oct 2018 05:14
Thanks.
Do you happen to know where to find the OEM if it can be sourced this days, Been out the game for a while.
09 Oct 2018 05:31
Any Kawasaki dealer can access OEM parts. Or you can order from Partzilla.
www.partzilla.com/catalog/kawasaki/motorcycle/1978
09 Oct 2018 06:46 - 09 Oct 2018 15:35
Once you get the part numbers from Partzilla or similar, you might want to plug them in at ebay to see if you can find a discount. Sometimes you get lucky...
Edit: found the guy with the viton seals... kzrider.com/kunena/profile/18962-dfigpz
Last edit: 09 Oct 2018 15:35 by Nessism.
- Sayonara
09 Oct 2018 18:19
Thanks I actually found them in partzilla, I guess standard price but in eBay people is asking crazy money. Thanks you guys are been great help.
- Big Jay
- Banned
