45 psi static compression no bueno
Re: 45 psi static compression no bueno
12 Oct 2018 06:12waktaylor wrote: Kawasaki Shop manual indicates 0.05-0.10 mm. I agree with everyone that leaving it alone will be fine for now. I may be pulling the head to check the bores. It sat so long Im sure there was rust and pitting. My CL350 was really bad at the bottom of the stroke.
I checked my book. I was wrong and waktaylor is correct. The clearance stated in the KZ1000 service manual is 0.05 to 0.10 mm. However 1979 supplement increased the clearance a max of 0.15 as I stated. However since this is a '78 KZ1000 the clearance should be 0.05 to 0.10.
The following user(s) said Thank You: waktaylor
- waktaylor
12 Oct 2018 07:18
This is good clarification. for now Im gonna leave the valves alone. My machinist guy is 6 months behind, does anyone have a suggestion for a machinist? Birmingham AL area or Atlanta GA or mail in...
'78 KZ1000A
www.kzrider.com/forum/11-projects/609320-wakt-out-kz1000#792182
77 KZ650
www.kzrider.com/kunena/11-projects/60951...ut-1977-kz650#793809
77 KZ650
- waktaylor
16 Oct 2018 13:32
Decided to send head and cylinder to Pit Stop Performance. #2 rings were stuck. Very hard black crud had everything gummed up and nasty. Fingers crossed it wont need new valves. I took a peek at one exhaust valve and the sealing surface looked like the face of the moon
'78 KZ1000A
77 KZ650
77 KZ650
- waktaylor
05 Nov 2018 12:33
Verified that my compression gauge is ok. That kz1000 engine was just toast. All the rings were stuck in the pistons and the valves looked like shit.
The KZ650 I just picked up has about 150 across the board so I’m gonna say my gauge is ok.
'78 KZ1000A
77 KZ650
77 KZ650
