45 psi static compression no bueno
  • waktaylor
  • waktaylor's Avatar Topic Author
07 Oct 2018 19:17 - 07 Oct 2018 19:19
#791991
Back story: I recently purchased a 1978 KZ1000 that has been sitting for around 4 years.
Here's what has been done this far:
Degreased engine externals- no real oil leaks but years of nasty.
PB Blaster into plug holes. Hoping this could loosen the rings IF they are stiff or stuck.
Oil change - old stuff was very spent but no metal that I could see.
Wired George has the carbs.
Static compression check is giving me about 30 psi on each cylinder even after several compression strokes.
I do have a cheap gauge that could suck.
Checked valve clearances. 6 are out of spec with too much gap and 2 are barely in spec. See chart below.
Will these specs cause that low of compression? Plan is to attempt to run the engine AS IS when refurbed carbs arrive. IF it does run I will redo compression check.
If it doesn't run should I get the valves in spec and go from there? IF I have to tear the top end down I will want some "hotter" cams so shims now will be a waste since the new cam will want what it wants.
Note: each valve has 2 clearance values indicating the thickest that goes in and next size up that doesn't. I have a basic set of feeler gauges so the formula averages these 2 numbers for further calculations to determine desired shim thickness for .080mm clearance.
Your browser does not support embedded PDFs. Please download the file here: Download PDF.
Last edit: 07 Oct 2018 19:19 by waktaylor.
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 45 psi static compression no bueno
07 Oct 2018 20:01
#791995
A wide gap will help compression.
Check cam timing marks.
When an engines sits sometimes they need to be run to reset the rings.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: waktaylor
  • Nessism
  • Nessism's Avatar
08 Oct 2018 05:03
#792003
I'd do the shims now. At least on the valves with tight clearance. And did you follow the cam position procedure detailed in the factory manual or did you simply point the cam lobe away from the valve when checking the clearance? If you did the later the clearances will show more clearance than in actuality due to skewing the cam in the journal clearance.
  • waktaylor
08 Oct 2018 06:36
#792005
It seems all the valves are wide gapped. I used the lines in the end of the cams to aim the lobes. I measured all of them several times.
  • loudhvx
  • loudhvx's Avatar
08 Oct 2018 08:38
#792011
All four being low could be the gauge. Make sure the check valve is in the tip of the gauge and holds pressure.
  • hardrockminer
  • hardrockminer's Avatar
08 Oct 2018 09:49
#792018
I posted earlier but it appears to have disappeared into the bit bucket.
Where do you get 0.08 as the spec? I don't have my book in front of me but from memory it's 0.05 to 0.15. The clearance is measured by the thickest gauge you can fit under the cam lobe. There should be no averaging necessary and you should be aiming for 0.15 because the gap decreases over time. You have five valves in spec and three on the high side, but not unduly so. I would leave them alone for now and concentrate on running the engine before you set valve clearance.
Your compression seems low but what's important is to have nearly the same (+- 15 psi between high and low) compression across the cylinders. Perform the test with all plugs out and the throttle wide open. Crank the engine until you see the greatest reading on the gauge. Normally it should be done with a warm engine, so don't put too much stock in readings on a cold test except to know you have compression.
  • waktaylor
08 Oct 2018 12:23
#792029
Thanks for your reply.
I figured I over complicated that.
The .08 was since people are saying .05-.1 mm was ok.
Carbs are in a different State so no need to block them open they aren’t on the engine.
Check valve is there.
Plugs removed
Ran starter at least 50 revs for at least 5 compressions.
All cylinders around 35-40 psi.
When carbs arrive I’ll see if it runs and retest.
Sounds like we agree about leave valves along for now.
  • hardrockminer
08 Oct 2018 13:45
#792034
0.05 to 0.10 is the spec for a Z1 or KZ 900 engine. The spec for a KZ 1000 is 0.05 to 0.15.
  • waktaylor
08 Oct 2018 14:30
#792035
If this is case I’m all good there.
  • zukdave
  • zukdave's Avatar
08 Oct 2018 15:55
#792047
I'd put about two table spoons of oil in all cylinder's let it sit over night and retest comp.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • waktaylor
08 Oct 2018 16:49
#792050
I think at this point I’m gonna wait for the carbs and attempt to run it. Luckily I’m out of town till next week so it won’t drive me nuts wanting to fix it.
Most of my suspension stuff has arrived but someone decided they liked my wheels too much and stole them
  • waktaylor
11 Oct 2018 20:32
#792181
Kawasaki Shop manual indicates 0.05-0.10 mm. I agree with everyone that leaving it alone will be fine for now. I may be pulling the head to check the bores. It sat so long Im sure there was rust and pitting. My CL350 was really bad at the bottom of the stroke.
