Removing aluminum cam plugs
- loneagle
09 Sep 2018 15:37
I installed some aluminum cam plugs when I rebuilt my engine and now I have one that leaks. I used Three Bond sealant when I installed, I must have not used enough. I'm concerned because the cam plugs were a tight fit and had to be lightly tapped in. I don't want to break the cylinder head trying to remove the plug. If anyone has any suggestions, please advise and thank you!
'78 Kawasaki KZ 1000
'02 Harley FXDWG
'16 Harley Street Glide
'02 Harley FXDWG
- daveo
Re: Removing aluminum cam plugs
09 Sep 2018 16:13 - 09 Sep 2018 16:17
I have one cam-end plug seam that leaks a tiny amount of oil too, and used Three Bond 1211 on mine.
Thinking I'll snug-fit a drill bit shaft in the plug-hole, and leverage it to rotate all the plugs free without much effort. Then clean them all up and do a better job sealing them in next time once the head is installed.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 09 Sep 2018 16:17 by daveo.
The following user(s) said Thank You: loneagle
09 Sep 2018 16:22
Per the OPs information 1978 KZ 1000
No bolt holes in cam end plugs
You should be able to just tap them out
Use a small piece of hardwood against the plug to protect the aluminum from being marred or distorted
I use Yamabond on mine with good results
The following user(s) said Thank You: daveo, loneagle
- daveo
09 Sep 2018 17:38
Often wondered about eliminating the hole in the later models with permanently mounted aluminum plugs, Would be nice to get rid of those four seemingly useless bolts.
- loneagle
09 Sep 2018 19:10
Thanks for the advice guys! I'm going to give it a go with the hardwood dowel. It may be a lot easier than I'm anticipating. I hate oil leaks, especially on a freshly rebuilt engine!
'02 Harley FXDWG
'02 Harley FXDWG
