Weird noise from crankcase
  • Calvin9819
  • Calvin9819's Avatar Topic Author
Re: Weird noise from crankcase
08 Sep 2018 19:23
#790523
That’d be awesome loud, if you wouldn’t mind. thank you. Maybe I’ll take the cover to the local hardware store and check if they’ve got pins there I could buy, and I’ll just order a gasket.
  • loudhvx
  • loudhvx's Avatar
08 Sep 2018 19:25 - 08 Sep 2018 19:26
#790524
No eBay APP ID and/or Cert ID defined in Kunena configurationEbay $4.50. For $15 you can be done with it and move on.
Last edit: 08 Sep 2018 19:26 by loudhvx.
  • loudhvx
  • loudhvx's Avatar
08 Sep 2018 19:29 - 08 Sep 2018 19:37
#790525
No eBay APP ID and/or Cert ID defined in Kunena configurationVerify the gasket part number. I didn't check.
Last edit: 08 Sep 2018 19:37 by loudhvx.
  • old_kaw
  • old_kaw's Avatar
08 Sep 2018 19:31 - 08 Sep 2018 21:26
#790526
Calvin9819 wrote: That’d be awesome loud, if you wouldn’t mind. thank you. Maybe I’ll take the cover to the local hardware store and check if they’ve got pins there I could buy, and I’ll just order a gasket.
The dowel is metric 8mm, it is hollow, and pretty cheap to buy oem parts along with an oem gasket at the same time..
Z1 sells them, ebay has them.
1981 Kawasaki Kz1000K1
Last edit: 08 Sep 2018 21:26 by old_kaw.
  • Calvin9819
08 Sep 2018 19:35 - 08 Sep 2018 21:46
#790528
Look don’t be so condescending, I appreciate all your help but the snide remarks are completel unnecessary. I’m just trying to get some help on here, don’t need to be treated like a 12 year old.
Thank you loud, I’ll look into those links. Either going there or partzilla, I was looking at the wrong diagram, the one you had was right. I appreciate all the help!
Last edit: 08 Sep 2018 21:46 by Calvin9819.
  • old_kaw
  • old_kaw's Avatar
08 Sep 2018 20:01 - 08 Sep 2018 21:24
#790529
Calvin9819 wrote: Look don’t be so condescending, I appreciate all your help but the snide remarks are completely unnecessary. I’m just trying to get some help on here, don’t need to be treated like a 12 year old.
I am glad someone found a micro phish showing the alignment dowels. on your model of bike. Good luck with that.
Last edit: 08 Sep 2018 21:24 by old_kaw.
  • Calvin9819
08 Sep 2018 20:15
#790531
I get it was meant to be humorous but it was on like every post you made. I’m new to all this, I’m just trying to get the full scope. Your advice is definitely helpful, I learned some good things from you. Especially about the tab which I’ll be looking into tomorrow. It just that it can be said in a helpful manner, instead of a condesending one. That’s all I’m sayin. In all, I do thank you for your help.
  • old_kaw
  • old_kaw's Avatar
08 Sep 2018 20:36 - 08 Sep 2018 21:23
#790534
Calvin9819 wrote: I get it was meant to be humorous but it was on like every post you made. I’m new to all this, I’m just trying to get the full scope. Your advice is definitely helpful, I learned some good things from you. Especially about the tab which I’ll be looking into tomorrow. It just that it can be said in a helpful manner, instead of a condesending one. That’s all I’m sayin. In all, I do thank you for your help.
I (and others) suggested better pics showing the entire cover and case so that people trying to help OR trying to learn from your problems can either see all of the bolt holes.
Last edit: 08 Sep 2018 21:23 by old_kaw.
  • Calvin9819
08 Sep 2018 21:02 - 08 Sep 2018 21:47
#790536
Yes I should have posted more pictures of the case. That’s on me. Im Glad we could resolve this problem. Are we good?
Last edit: 08 Sep 2018 21:47 by Calvin9819.
