Not shifting
- Jesse
Not shifting
24 Jul 2018 20:51
My bike will shift into 1st but boggs down like it was in 4th gear, when i got it Rollin it wont go into any other gear but nutral. I jacked the back tire up took out the plugs and i can get it in all gears? Do i have a clutch problem? Im at a loss here, any advice would be greatly appreciated
Re: Not shifting
25 Jul 2018 05:05
What bike are you speaking of ?
Pictures would help.
- Jesse
Re: Not shifting
25 Jul 2018 14:38
Clutch adjustment would be my first suspect.
Did this happen suddenly.
Didithappen after doing some other maintenance or repair?
- KZQ
- Administrator
Re: Not shifting
25 Jul 2018 15:15
Any chance it's the Kawasaki neutral finder that confusing you? Have you ever ridden the bike? Is it new to you? Many Kaws have a device that prevents you shifting up past neutral unless your going fast enough to actually get into second gear.
Bill
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
Riders:
Projects:
1985 ZN1300
- Jesse
Re: Not shifting
25 Jul 2018 19:24
It ran fine, the carb float was sticking so i cleaned them and tried to take it for a ride then it wouldn't shift into any gear except 1st and boggs down like its in 4th
- Jesse
Re: Not shifting
25 Jul 2018 19:32
I think i have a clutch problem, I've been riding it just fine except a little carb problem. Thanks bill
