1980 KZ550 start up after rebuild
- aleeka
16 Jul 2018 21:55
Hello everyone
I purchased a 1980 KZ550 with 50,000 miles. The bike ran great when I bought it but cam chain was stretched. Sense it was winter here in Colorado I tore the bike down and the motor and replaced the cam chain along with the primary. I just got done putting it all back together and now I am having some issues getting it to run...
Yes, I know there are about a million things that could be a play here considering I took the motor completely apart..
However, it seems like it not getting gas. The motor turns over fine but will not fire. This is my first attempt at a rebuild so I am just curious if I am missing something. Kinda hard to spray starter fluid in there with the airbox and carbs all sealed up..
Any suggestions would be really appreciated. I figured I would ask on here before I start improvising a way to start it
Re: 1980 KZ550 start up after rebuild
17 Jul 2018 04:59 - 17 Jul 2018 05:02
Did you double check the cam timing? Make sure the valve clearance is in spec? Use the petcock prime position to fill the carbs? Check spark?
Oh, and did you remove the cam chain tensioner spring pressure when you installed the valve cover? If not, your cam chain is over tensioned now.
Last edit: 17 Jul 2018 05:02 by Nessism.
17 Jul 2018 07:09
Also check to be sure that the coils are connected to the correct spark plugs. One coil fires cylinders 1& 4, the other one fires 2 & 3.
