81 kz650 Extra square bushing
- PastorPaul
11 Jul 2018 05:00
I dropped my pan to fetch a cam tensioner bushing and found a second one I cannot place on partzilla diagrams or in the service manual.
Its about half the size as the idler bushings and marked UP just like them.
I juxtaposed it so you can see... I'm at a loss here.
Re: 81 kz650 Extra square bushing
11 Jul 2018 05:38 - 11 Jul 2018 05:39
Maybe a po dropped a cam guide damper down inside the engine & it got sheared by the cam chain or something. and then he left it in there & replaced it. ???
Last edit: 11 Jul 2018 05:39 by martin_csr.
- PastorPaul
11 Jul 2018 05:41
No its solid. If I was paying attention I think it may have been on the tensioner? Its thinner though and no Z mark.
- PastorPaul
11 Jul 2018 07:27 - 11 Jul 2018 07:32
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe stock tensioner doesn't have a damper like that & the damper end of the tensioner pushrod is round & not really removable.
Obviously, I'm not sure where it came from, but to my eye now that I'm on a computer it's kind of similar to the 92075-232 dampers found on the earlier 650s with roller came chain. Those also have a rectangular damper on the end of the tensioner pushrod, but it doesn't look the same.
... KZ650-C1 et al. 92075-232
... KZ650-CSR. 92075-1314
Last edit: 11 Jul 2018 07:32 by martin_csr.
- PastorPaul
11 Jul 2018 07:32
That was my thinking.
I'm wondering if Kawasaki dropped one in and no one would have ever known.
Bike only has 9 k on it. It died a painful valve train death at the hands of a teenager too... So who knows what they tried...
11 Jul 2018 07:35 - 11 Jul 2018 07:42
Who knows. I don't. :laugh:
The guy could've ordered the wrong part, tried it anyway, then got the right part?
edit: in case you aren't aware, there's a pdf available for the 1981 KZ650. jarlef z650 >>> files section
Last edit: 11 Jul 2018 07:42 by martin_csr.
