Break in engine oil
  • JohnLuke
  • JohnLuke's Avatar Topic Author
  • 1982 KZ750N Spectre
Break in engine oil
29 Jun 2018 14:22
#786100
What would be a good break in engine oil on a kz750?
I have seen a lot of different ideas, I just wanted to have a second opinion.
It would be nice if it was cheap :)
I plan on getting it started to see if there are any oil leaks. I’ll shut it off and send the frame off to go get painted. I just would rather try and see if I need to take it out b4 it gets painted. And if it blows......well it blows.
Thanks!
  • Nessism
  • Nessism's Avatar
Re: Break in engine oil
29 Jun 2018 14:52
#786101
Shell Rotella T4 15W-40. If you can't find that any standard diesel oil is fine.
  • JohnLuke
29 Jun 2018 17:37
#786110
Oh okay, I have plenty of that at my local Walmart. :)
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
29 Jun 2018 17:42
#786111
I also added 4 oz of zppd for the flat tappets
  • Nessism
  • Nessism's Avatar
29 Jun 2018 19:42
#786122
KZ shim engines are extremely easy on cams and tappets. A puddle of oil collects around the bucket and each time the cam comes around it gets a nice dip. It's old time V8 engines with flat tappet (mechanical) cams that have issues with lobes going flat, not KZ's.
  • JohnLuke
30 Jun 2018 00:13
#786135
Sweet!
