KZ750 crank question
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
20 Jun 2018 22:50
#785553
Aloha guys.
From what I searched and read, KZ650 and 750 have same stroke. Can the crank from KZ650 fits in 750?
I had a crank with broken dowel pin and took it to local machine shop and they wanted over $150 for the work. Decided to buy some used crank from evilbay instead. No classic Kawasaki nearby, so my next best is sad but evilbay. Came across several KZ750 cranks, but plenty of 650 as well. I haven't compare the price yet but if it fits, I'll include 650 crank as well.
Thanks for your help!
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: KZ750 crank question
21 Jun 2018 03:52
#785555
Possible yes.
www.cmsnl.com/kawasaki-kz650h2-csr-1982-...311028/#.WyuA_8Ysp-M
KZ650H2 CSR 1982 USA CANADA CRANKSHAFT ASSY
www.cmsnl.com/kawasaki-kz650h3-csr-1983-...311028/#.WyuB6cYsp-M
KZ650H3 CSR 1983 USA CANADA CRANKSHAFT ASSY
fits models
KZ750E1 1980 USA CANADA
KZ750E2 1981 USA CANADA
KZ750E3 1982 USA CANADA
KZ750F1 SHAFT 1983 USA CANADA / LTD
KZ750H1 1980 USA CANADA / LTD
KZ750H2 1981 USA CANADA / LTD
KZ750H3 1982 USA CANADA / LTD
KZ750H4 1983 USA CANADA / LTD
This product fits to 14 models. We are showing the first 10. Please log in to see all models.
Michael
  • Ojisan rider
21 Jun 2018 22:31
#785630
Thanks for the reply. I should've check the online catalog first. Forgot about this trick.
Guess I had one too many Jack...........
