LIGHT TAPPING NOISE
- brent456
LIGHT TAPPING NOISE
20 Jun 2018 05:26
I have a 1981 kz1100 and it made a light tapping noise when i started it up the other day but once engine warmed up went away. Any ideas. I was think exhaust leak
Re: LIGHT TAPPING NOISE
20 Jun 2018 05:44brent456 wrote: I have a 1981 kz1100 and it made a light tapping noise when i started it up the other day but once engine warmed up went away. Any ideas. I was think exhaust leak
Valve shim adjustment
20 Jun 2018 07:19
An exhaust leak can sound like a loose valve. It goes without saying that the valves MUST be checked and adjusted per the factory manual so I'd do that straight away regardless. Even with the valves okay, and there being no exhaust leaks, some light ticking during warm up is normal for these old bikes.
- brent456
20 Jun 2018 07:27 - 20 Jun 2018 07:27
Well i had the whole top end rebuild and piston re-ring. Also had 4 in one exhaust put on at the same time. only have maybe 400 miles on it since the rebuild.
Last edit: 20 Jun 2018 07:27 by brent456.
20 Jun 2018 17:03Nessism wrote: An exhaust leak can sound like a loose valve. It goes without saying that the valves MUST be checked and adjusted per the factory manual so I'd do that straight away regardless. Even with the valves okay, and there being no exhaust leaks, some light ticking during warm up is normal for these old bikes.
I agree with what Ed says above.
Exhaust leaks are common and sound like a valve ticking. But dont usually stop once the motor is warmed up.
So put a wrench on the exhaust nuts and eliminate this as a possible source of the tick ( easy )
Next Valves...
If the tick stops when motor warms up chances are the valve tolerances tighten up and this silences the tick.
If so the tick is from a valve which may even be in spec , but at the looser end of the specs.
You should recheck your valve clearances after a rebuild and periodically their after.
Its part of on going maintenance
Ride it and enjoy it
