HELP! - 1981 KZ750(E1) Starter Clutch Issues 19 Jun 2018 07:52 #785421
  • ryanlewis85
  • ryanlewis85's Avatar Topic Author
  • Thank you received: 0
Hey! I checked the starter clutch itself, and it is 100% new, including the threads, just like your picture.
I think the only thing i've left to replace is the housing with the rollers/pins/springs.
HELP! - 1981 KZ750(E1) Starter Clutch Issues 19 Jun 2018 08:12 #785423
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Thank you received: 1899
Sounds good, if the ramps are flatten out you won´t get any grip.
HELP! - 1981 KZ750(E1) Starter Clutch Issues 19 Jun 2018 08:25 #785426
  • ryanlewis85
Thanks!
Sorry for lack of knowledge, but are you referring to the grooves on the starter clutch gear itself (the thing we just discussed), or are you talking about another part?
I'm now trying to source a new "housing" for the rollers/springs. Looks like part number 13193-1012 on the schematic, but all the parts I look at online do not LOOK like that housing...
HELP! - 1981 KZ750(E1) Starter Clutch Issues 19 Jun 2018 13:25 #785436
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
My last post, "ramps are flatten out", is relate to the housing for the rollers/pins/springs.
Happy wrenching
Michael
HELP! - 1981 KZ750(E1) Starter Clutch Issues 26 Jun 2018 10:16 #785922
  • ryanlewis85
THANK YOU ALL!
Guys, quick update. After upgrading EVERYTHING in the starter clutch EXCEPT for the housing with the rollers/pins/springs, we FINALLY did upgrade the housing.
Sure enough, it worked/started up like a champ. Now my broken bike is free again, and i'm happy as can be.
Thank you all so much for your advice and guidance. I still am very ignorant, but truly have learned so much over the past 6 months, thanks to you all!
HELP! - 1981 KZ750(E1) Starter Clutch Issues 26 Jun 2018 12:27 #785924
  • Daftrusty
  • Daftrusty's Avatar
  • Thank you received: 184
