"Wanted" A Decent Pair of OEM 30 Tooth Camshaft Sprockets For The Z1- KZ900
  • z1kzonly
  • z1kzonly's Avatar Topic Author
07 Jun 2018 17:21
#784757
Hi, I could use a set of OEM 30 tooth camshaft sprockets. Z1-KZ900- KZ1000. I have a nice set of Mark II, low mile camshafts with 32 teeth. For the big pin crankshaft.
Jut another project on the back burner. Maybe someone has a set of bad cams with the sprockets still attached?
Just checking.
Thanks in advance
  • DFIGPZ
  • DFIGPZ's Avatar
Re: "Wanted" A Decent Pair of OEM 30 Tooth Camshaft Sprockets For The Z1- KZ900
10 Jun 2018 12:34
#784900
I more than likely have a few sets of these on hand.
Barry
1984 750 Turbo
  • z1kzonly
10 Jun 2018 14:49
#784902
Hi Barry, I sent you an I M.
Thanks. Whatever works for you?
I will appreciate it.
Thank You.
Marty in Buffalo
