Help me please! Starter motor
  • Tesk
  • Tesk's Avatar Topic Author
23 May 2018 13:56
#783889
My bendix is stuck. I have dismantle the starter motor completely and it was working just fine, but now ita the same problem again. I have changed the carbons and cleaned the inner parts and everything, but the bendix keeps getting stuck. I do not want to go around with a hammer to start the bike everytime
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Help me please! Starter motor
23 May 2018 16:47
#783898
Bendix? What bike is this?
23 May 2018 18:27
#783904
Good question; is this starter on a Kawasaki? I don't know of any KZ that uses a starter with a Bendix. Ed
  • Tesk
23 May 2018 19:58 - 23 May 2018 20:01
#783907
SWest wrote: Bendix? What bike is this?
650ed wrote: Good question; is this starter on a Kawasaki? I don't know of any KZ that uses a starter with a Bendix. Ed
My bike is a kawasaki kz 750 ltd 1982
Last edit: 23 May 2018 20:01 by Tesk.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2018 20:17
#783909
Chances are the bushings are worn out.
  • Tesk
23 May 2018 20:51
#783913
SWest wrote: Chances are the bushings are worn out.
Can I fix that? Bushings are the black square thingy? I already replaced that
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 May 2018 21:01
#783914
The bushings are the bearings. If they are sloppy the starter will drag and eventually won't work at all.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
24 May 2018 11:42 - 24 May 2018 11:43
#783951
Tesk wrote: Can I fix that? Bushings are the black square thingy? I already replaced that
The " black square thingies" are likely the brushes that contact and supply power to the copper commutator. The commutator is the copper component (at the left end (n your pec) of the armature that has the many axial slots. Each opposing pair of commutator contacts supplies 12vdc to the windings of the armature as it rotates.
The bushings/bearings are what the armature shaft rotates in in the end caps.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 24 May 2018 11:43 by slmjim+Z1BEBE.
