Cam Choices ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Cam Choices ?
21 May 2018 04:49
#783760
Pulled my 77' KZ1000A motor out yesterday in prep. for 1075 kit. Like to look into a good "street" cam upgrade since I'm still going to use 28mm pumper and my 4into1 exhaust.
I've read that early Z1 cams have a better profile than my stock cams or even early GPZ1100 cams would be good ? Without having to go to "aftermarket" cams, Do you guys have any suggestions ?
77' KZ1000A
  • hardrockminer
  • hardrockminer's Avatar
Re: Cam Choices ?
21 May 2018 05:33
#783763
I believe the cam profiles are the same, although very early Z1 cams were hollow. Valve clearance tolerance on your bike is a bit more than on Z1's.
  • zed1015
  • zed1015's Avatar
Re: Cam Choices ?
21 May 2018 05:55
#783766
All 72 Z1 to 1980 Z1R/MK2 are pretty much the same profile give or take the odd fraction due to factory tolerances and wear.
The only stock cams that will make a favourable difference are from the 83 onwards GPZ1100A Unitrack or Z1100R ( approx 9.7mm lift) and you will need APE adaptor sprockets for them to fit.
Beware that GPZ cams from the german market bikes are milder due to the 100 bhp limit they have/had in force..
  • kzdcw
  • 77' KZ1000A
Re: Cam Choices ?
21 May 2018 19:48
#783815
Zed1015, Looks like the 83 & 84' GPZ1100 cams are the ones you want as they appeared to increase in duration to 300 degrees and 9.7mm lift.
Now to locate them, ANYONE ?
77' KZ1000A
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Cam Choices ?
25 May 2018 18:06
#784020
kzdcw wrote: Zed1015, Looks like the 83 & 84' GPZ1100 cams are the ones you want as they appeared to increase in duration to 300 degrees and 9.7mm lift.
Also Remember 83 /84 GPZ 1100 cams do not have provision for Tach drive if needed ?
1984 750 Turbo
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Cam Choices ?
25 May 2018 18:51
#784028
Hello, we have no speed limit on the highway:P :P :P :P :P
but i have to know the US/German cam lift value/difference
