Can this be right????
- zed1015
Re: Can this be right????
25 May 2018 11:23menace wrote: Thats some pretty solid info thanks. i have them set all across the board perfect but i didnt set them to the master i just made them all even. Should i redo it then?
On the VM round slide carbs there is no master.
They all have adjusters under the carb top.
Carbs with a master only have adjustment on three and the master has the idle screw .
Just balance them to the carb with the lowest vac reading as that should prevent you from adjusting them toward the limit of the adjusters.
If you have them set perfect then leave them at that.
The following user(s) said Thank You: Scirocco
25 May 2018 15:04
Thank you zed1015 for the additional information.
