Lockhart oil cooler
  • 1977_KZ650C1_WV
  • 1977_KZ650C1_WV's Avatar Topic Author
Lockhart oil cooler
08 May 2018 09:46
#783073
I have a 1977 KZ650C1 with a lockhart external cooler will it require more oil when I change it?
1977 KZ 650C1 with 3 phase charging Lockhart oil cooler 4 into 1 header with pod filters
  • 1977_KZ650B1_WV
  • 1977_KZ650B1_WV's Avatar
Re: Lockhart oil cooler
08 May 2018 10:15
#783074
I guess if it's between the lines on the oil window it should be okay. I just changed it and added 3 quarts it looks like it has enough judging by the oil window lines.
1977 KZ-650C1
3 phase excited field system
  • zed1015
  • zed1015's Avatar
08 May 2018 10:17
#783075
No.. Just fill with the specified amount of oil as quoted in the manual.
However ! If your cooler has the hose fittings on the top of the cooler matrix it will hold a small amount of oil that will not drain back into the engine at rest and this will give the system a slightly larger oil carrying capacity.
If this is the case, once run and then left to settle overnight you can top up the oil in the engine back up to the upper sight glass mark to account for this.. Just remember to also drain the cooler of old oil at service time.
The following user(s) said Thank You: 1977_KZ650B1_WV
