KZ440 LTD Compression Woes
- jimbrickland
27 Apr 2018 17:15
Hello KZ Riders! I have just finished reassembling a 1983 KZ440 engine. I initially tested the compression in both cylinders and found it to be above service limit (107psi) but below the spec in the manual (156psi). I replaced the piston rings, base gasket, head gasket, and cleaned and lapped the valves. I am reading about 125 in the right cylinder and 90 in the left. When I added some oil to the left cylinder the compression shot up to about 135 psi. I know that would generally suggest the piston rings are not sealing well. However, I am at a loss. I am no expert but I followed the manual as well as I was able to. I am willing to tear it down again but I was looking for advice to make sure that I don't run in to the same issue the next time. As always, thank you guys for your help.
1976 KZ750B my one and only
1983 KZ440 LTD my one and only's one and only
- azman857
Re: KZ440 LTD Compression Woes
27 Apr 2018 18:02
Measure the piston to cylinder wall clearance?
The following user(s) said Thank You: jimbrickland
27 Apr 2018 19:03
Adding oil to a cylinder to determine whether or not the rings are not sealing can be deceptive. See the link below for an explanation. Ed
www.kzrider.com/forum/2-engine/608083-wo...e-guide-seals#780709
27 Apr 2018 19:23 - 27 Apr 2018 19:23
Did you bottle brush hone the cylinders? How many miles on the engine since the rebuild. What break in procedure was used? Compression test with throttle held open? Valves properly adjusted?
Last edit: 27 Apr 2018 19:23 by Nessism.
- jimbrickland
28 Apr 2018 06:40
Thanks for the replies. I did hone the cylinders but I used a three stone style cylinder hone. I have not ridden the bike more than a couple miles to warm it up and retest the compression with the throttle wide open. If there are break in procedures available that would be great. The only adjustment I made to the valves was to clean and lap them and install new valve stem seals.
- jimbrickland
28 Apr 2018 06:52
I found this post from wiseco,
blog.wiseco.com/proper-engine-break-in-after-a-rebuild
, Seems to be comprehensive. Any thoughts or recommendations otherwise?
- Nebr_Rex
28 Apr 2018 08:33
Put some miles on it.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
