Removing Engine ?
- kzdcw
- 77' KZ1000A
Removing Engine ?
20 Apr 2018 18:00
Should have my Wiseco 1075 kit next week so will have to pull my motor ( 77' KZ1000A ) to rebuild. Bike runs pretty decent for what it is but excited getting started
Besides the obvious, what the easiest way to remove motor from the frame being a one man show ? Any Tips would be greatly appreciated !
77' KZ1000A
Re: Removing Engine ?
20 Apr 2018 18:22
An upside milk crate alongside the frame to slide the engine onto works for me. You can also lay the bike down on it's side and lift the frame off the engine if you don't have the strength to wrestle the engine out.
20 Apr 2018 19:00
Take the top end off then remove the cases.
- kzdcw
- 77' KZ1000A
20 Apr 2018 19:45
Nessism, I'll keep the Bike upright and use the milk crate route. Hopefully can the leave the Engine intact as I slide it over the frame to rest on the crate. Then the Builder ( Bill ) can do his magic.
77' KZ1000A
- bluej58
21 Apr 2018 05:46 - 21 Apr 2018 05:56
I have made improvements since 2011 but this is what I do.
Note: if you drain the oil and remove the oil filter it's a big help not having to deal with getting past those lugs , a little messy thou
www.kzrider.com/forum/2-engine/489872-ho...ved-my-engine#489872
78 KZ1000 A2A
Last edit: 21 Apr 2018 05:56 by bluej58.
- DFIGPZ
21 Apr 2018 06:36SWest wrote: Take the top end off then remove the cases.
1984 750 Turbo
- KZB2 650
21 Apr 2018 06:40 - 21 Apr 2018 06:51
I used Blue's method twice once with the top end removed and one without......... back in together too but I had the wife giving me a hand to be sure I didn't beat things up.
As everything I do I worried and worried and it was out easy and in in a flash.......... One thing I wanted to add is I taped cardboard on the frame rails and ex studs to help protect the paint too,
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 21 Apr 2018 06:51 by KZB2 650.
- bluej58
21 Apr 2018 07:38
Here is another good thread on using a hoist , with a revised version of my method.
www.kzrider.com/forum/21-tools/604158-li...ist-by-intake#745997
78 KZ1000 A2A
- ajsfirehawk
21 Apr 2018 09:56
The bracket and hoist pics are mine from a couple years ago. It works very well for me. But I need to be clear I've only used that method on KZ650's and 750's. I've not done this on a 1000cc or an 1100. They are bigger, heavier and I do not know how much weight the intakes will handle. It may work just fine, but I haven't done it.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
