82 kz1000m cylinder head nut torque
  • Shinglejohn
  • Shinglejohn's Avatar Topic Author
09 Apr 2018 14:27
#781557
The clymer manual specifies 30 ft lb for the nuts on the posts. That seems high, can anyone confirm this?
  • TexasKZ
  • TexasKZ's Avatar
  • Busy
Re: 82 kz1000m cylinder head nut torque
09 Apr 2018 15:38
#781565
Here is a link to the factory service manual
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
  • zed1015
  • zed1015's Avatar
10 Apr 2018 02:04 - 10 Apr 2018 03:58
#781600
Early manuals used to state 25 ft lb and later ones increased that to between 27 to 31 ft lb. (this is with stock compression).
With stock studs 32 ft lb is deemed as the maximum and with HD studs 42 ft lb.
Whatever torque you go for just remember to re-torque after it's cooled down from the first warm up and then again after a few hundred miles.
Last edit: 10 Apr 2018 03:58 by zed1015.
The following user(s) said Thank You: Shinglejohn
