82 KZ 1100 Spectre ...oil pan gasket question.
  • RLBuddi
  • RLBuddi's Avatar Topic Author
10 Mar 2018 18:37
#780043
Should oil pan gasket be installed with gasket sealer or Yamabond? Or dry? Please advise. Thanks!
PS: I did do a forum search, but unable to find specific answer.
  • Nessism
  • Nessism's Avatar
Re: 82 KZ 1100 Spectre ...oil pan gasket question.
11 Mar 2018 06:18 - 11 Mar 2018 06:19
#780055
I'm not specifically familiar with the 1100 but on the 750 the sump gasket is to be installed dry. The factory manual specifies dry unless specific use of sealer is highlighted.
Last edit: 11 Mar 2018 06:19 by Nessism.
The following user(s) said Thank You: RLBuddi
