Kz650 Timing Chain
- Firefly38
Kz650 Timing Chain
08 Mar 2018 09:44
Hi. First Post.
I have a 78 Kz650. There is still some top end noise from the timing/cam chain. Have changed the chain and 3 idler pulled and replaced the spring in the tensioner but it still does not seem quite right.
Question is.... Is there a mod to make the tensioner work better? Something from a later bike or a home mod.
It runs better than before but I feel it should be tighter.
Thanks in advance.
Thanks in advance.
Re: Kz650 Timing Chain
08 Mar 2018 14:37
Is there slop when you turn the crank forward and back with a wrench?
The following user(s) said Thank You: Firefly38
- Firefly38
08 Mar 2018 15:23
Yes. If you wind the engine forward then it's fine. If you wind the engine the other way then there is some slack.
- rstnick
08 Mar 2018 16:43
Welcome.
There are aftermarket tensioners available from Ape and Kruegen?
A manual tensioner, basically a long bolt with a lock nut.
These are noisy engines though, so what your hearing could be normal.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
The following user(s) said Thank You: Nessism, Firefly38
08 Mar 2018 16:59
Did you replace the center roller? Last time it and the front guide wore out.
- Firefly38
09 Mar 2018 07:34
Replaced all the bearings in the wheels but not the rollers. Didn't seem to have any wear on them.
I've looked up the Ape tensioner above so will try that. Can only see then in the US though?
- Busy
09 Mar 2018 09:21
Are the carburetors perfectly synchronized? If not, they can cause an amazing amount of top end racket, even with new chain, rollers, etc.
- ajsfirehawk
09 Mar 2018 10:13TexasKZ wrote: Are the carburetors perfectly synchronized? If not, they can cause an amazing amount of top end racket, even with new chain, rollers, etc.
Great point TexasKZ. I didn't think of it when I read this thread, but when you dial in the sync it certainly does quiet things down. Valves being set to the wide end of spec will create more noise as well.
80 KZ1000 Z1 Classic
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
- Firefly38
10 Mar 2018 00:00
They should be as it's just had a top overall but I will recheck.
I've ordered one of those adjusters from Ape too.
- ajsfirehawk
11 Mar 2018 11:41Firefly38 wrote: Yes. If you wind the engine forward then it's fine. If you wind the engine the other way then there is some slack.
What you describe above is normal. That is why they always have you check the timing mark rotating the engine forward and not backing it up at all.
83 KZ1100 LTD
18 Z900RS
23 Mach 1
83 KZ1100 LTD
18 Z900RS
23 Mach 1
