Piston Ring Choice: Genuine Kawasaki 13008-5037 or Aftermarket?
  • daveo
  • daveo's Avatar Topic Author
  • Premium Member
  • Premium Member
01 Mar 2018 20:17 - 02 Mar 2018 07:04
#779630
Saving money is great, but both ring sets are made in Japan.
Perhaps they are the exact same rings, but one doesn't come with KAWASAKI HEAVY INDUSTRIES, LTD. printed on the package.
:unsure:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 02 Mar 2018 07:04 by daveo.
  • daveo
  • Premium Member
  • Premium Member
Re: Piston Ring Choice: Genuine Kawasaki 13008-5037 or Aftermarket?
19 Mar 2018 00:07 - 19 Mar 2018 00:07
#780433
NIPPON vs. GENUINE KAWASAKI
What disadvantages might be experienced by going with the aftermarket piston rings in this case?
Last edit: 19 Mar 2018 00:07 by daveo.
  • Nessism
  • Nessism's Avatar
19 Mar 2018 18:48
#780486
Most likely those Nippon rings will be okay but there is no guarantee. With OEM Kawasaki parts you KNOW they will work.
  • daveo
  • Premium Member
  • Premium Member
19 Mar 2018 21:17
#780491
Nessism wrote: Most likely those Nippon rings will be okay but there is no guarantee. With OEM Kawasaki parts you KNOW they will work.
Appreciate the reply, thank you!
I figured at least one forum member would have had re-ringed with a set of Nippon rings, since they are readily available and cost effective (cheap).
Z1E stocks a set Made in Japan:
www.z1enterprises.com/725mm-piston-rings-kz1100.html
Ebay listing has Nippon brand, also Made in Japan:
Not sure I'm ready for a re-ring project, but I have a good Std. bore cylinder block honed and ready, and the nos pistons that I used in my Spring 2015 top-end assembly should be usable with about 20K miles on them. Seems I have everything needed but adequate work space, and the motivation to do it.
Prior to Winter storage I was adding oil more often than I like, and have since rearranged interests. But I tell you what, when I got old red running again the other day, the short spin I took was very exhilarating...so please don't count me out just yet.
B)
